Replaced Edge node from Edge cluster holding logical-routers
Article ID: 423569
VMware NSX VMware vSphere ESXi
  • An NSX Edge node is replaced from the Edge Cluster with a new NSX Edge node.
  • After replacement, the old NSX Edge node still holds logical-routers.
  • The new NSX Edge node added to the Edge cluster does not have any logical-routers realized.
  • The NSX environment was previously NSX-T 3.x.
Logical Routers are listed in the UI under System > Nodes, or via the CLI of the NSX Edge node: get logical-routers
VMware NSX
This issue is resolved in VCF 9.1.1, available at Broadcom downloads.
If you are having difficulty finding and downloading software, review the Download Broadcom products and software KB.
If you believe you have encountered this issue, open a support case with Broadcom Support and refer to this KB article.
For more information, see Creating and managing Broadcom support cases.
If you are contacting Broadcom support about this issue, provide the following:
  • NSX Manager support bundles.
  • NSX Edge nodes support bundles.
  • Text of any error messages seen in NSX GUI or command lines pertinent to the investigation.
Handling Log Bundles for offline review with Broadcom support:
Collect Support Bundles for Troubleshooting VMware NSX
Uploading files to cases on the Broadcom Support Portal
