Data Warehouse (DWH) known issues
Article ID: 212329
Clarity PPM On Premise Clarity PPM SaaS
Known issues related to Data Warehouse (DWH) including:
  • Job failures
  • Data issues
  • Performance
As the list of articles below is not a full list of KBs for DWH issues, if a match for your issue isn’t found below, also search using the Broadcom support search portal. See Known Clarity issues: Tips in using self service.
General Troubleshooting
It's recommended to review the Troubleshooting guide first as this can assist in uncovering the root cause.
Known Defects
Under Review
Fixed in 16.0.1
Fixed in 16.0
Fixed in 15.9.3
Fixed in 15.9.2
Fixed in 15.9.1
Fixed in 15.9
Data
DWH Bean
DB Link
DWH Slices
Job Failures
For job failures, checking the job logs and bg-dwh.logs can help narrow down the related error. See Load DWH job failures - troubleshooting for further details / troubleshooting. If the related error is not found below, check the knowledge base as well for related issues.
Post Refresh
New Environments
Oracle Specific
ORA-00001
ORA-00600
ORA-00904
ORA-00942
ORA-01400
ORA-01407
ORA-01427
ORA-01722
ORA-01775
ORA-12899
ORA-01555
ORA-01735
ORA-02019
ORA-02298
ORA-02049
ORA-04036 / ORA-02063
ORA-30926
ORA-04063
ORA-04020
ORA-04022
ORA-06502
ORA-28000
SQL Server Specific
Postgres (PG)
All Databases
Load DWH Access Rights job
Studio (Objects/Attributes)
Tables
Time Periods
Jaspersoft Domains
Upgrade/Compatibility
Including issues with incompatibility
See also Clarity frequently reported issues
