Jobs not running due to out of order parent jobids - Applications Manager
Article ID: 88751
Automic Applications Manager
Applications Manager may stop processing jobs following a system crash, network outage, or running out of Java memory.
Symptoms
In the RmiServer logs, you will see recurring errors similar to: Jobid #### came in out of order, parent jobid is ####
This occurs when a job in the backlog or history cannot find its parent jobid, causing the RmiServer to enter a processing loop. This often results in high CPU usage and subsequent Java heap errors.
The "out of order" error is typically a secondary symptom of an earlier failure (like a Java OutOfMemory error) that prevented the parent job's state from being correctly recorded.
  1. Prerequisite: If the issue was caused by a Java memory failure, first follow the steps in KB 88261: Increasing Java Memory available to Applications Manager to increase the memory allocation.
  2. Stop the Applications Manager processes.
  3. Log into SQL-Plus and run the following queries to identify the problematic records:
    sql
    select count(*) from so_job_queue where so_jobid='<Jobid_from_error>';
    select count(*) from so_job_history where so_jobid='<Parent_jobid_from_error>';
  4. Remove the offending records:
    sql
    delete from so_job_queue where so_jobid='<Jobid_from_error>';
    delete from so_job_history where so_jobid='<Parent_jobid_from_error>';
    commit;
  5. Restart the Applications Manager processes.
For instructions on how to download the latest product releases or patches, see Download Broadcom Products and Software.
To speak with a customer representative or a Support Engineer, see Contact Support. Scroll to the bottom of the page and click on your respective region.
