Scenarios where the information within this KB may be useful:
The procedure found within the Resolution section applies exclusively to NSX Edge nodes within a VCF-managed Federated environment. This procedure is NOT valid for standalone NSX-T Federation deployments. Do not attempt this procedure on environments outside of VCF orchestration.
Vmware Cloud Foundation
NSX Federated
The standard Expand/Shrink methodologies for migrating an Edge Cluster cannot be used on a Federated Environment, as the Edge Cluster cannot be "shrunk".
