[Host] pktcap-uw --switchport [Pod Switchport] --capture VnicTx,VnicRx -o - | tcpdump-uw -enr -[Timestamp] ##:##:##:##:##:01 >##:##:##:##:##:02:, ethertype IPv4 (0x0800), length 74: 10.10.0.10.1234 > 20.20.20.20.53: Flags [S], seq [Seq], win 64240, options [mss 1460,sackOK,TS val [Val] ecr 0,nop,wscale 6], length 0[Host] pktcap-uw --uplink [vmnicx] --capture UplinkSndKernel,UplinkRcvKernel -o - | tcpdump-uw -enr -[Timestamp] ##:##:##:##:##:03 >##:##:##:##:##:04, ethertype IPv4 (0x0800), length 132: 30.30.30.30.5678 > 30.30.30.31.6081: Geneve, Flags [none], vni [VNI], proto TEB (TEB), options [8 bytes]:##:##:##:##:##:01 >##:##:##:##:##:02, ethertype IPv4 (0x0800), length 74:10.10.0.10.1234 > 20.20.20.20.53: Flags [S], seq [Seq], win 64240, options [mss 1460,sackOK,TS val [val] ecr 0,nop,wscale 6], length 0
[ESX]$ esxcli software vib list | grep -i rtmnsxt-rtm 0 152
VMware NSX-T Data Center 3.2.x
VMware NSX 4.x
VMware Tanzu for vSphere
This issue is resolved in VMware NSX 4.2.3, available at Broadcom downloads.
If you are having difficulty finding and downloading software, please review the Download Broadcom products and software KB.
To workaround this issue, reboot all hosts that contain the stale RTM VIB.
