"File system specific implementation of Ioctl[file] failed Failed to start the virtual machine. Module 'Disk' power on failed. Cannot open the disk '/vmfs/volumes/vm file path/vmname.vmdk' or one of the snapshot disks it depends".
/vmfs/volumes/<datastore uuid>/<VM Name>/vmware.log:YYYY-MM-DD:T:HH:MM:SS In(05) vmx - [msg.migrate.resume.fail] The VM failed to resume on the destination during early power on.YYYY-MM-DD:T:HH:MM:SS In(05) vmx - [msg.moduletable.powerOnFailed] Module 'Disk' power on failed.YYYY-MM-DD:T:HH:MM:SS In(05) vmx - [msg.disk.noBackEnd] Cannot open the disk '/vmfs/volumes/<datastore uuid>/<VM Name>/<RDM Disk>.vmdk' or one of the snapshot disks it depends on.YYYY-MM-DD:T:HH:MM:SS In(05) vmx - [msg.fileio.lock] Failed to lock the fileYYYY-MM-DD:T:HH:MM:SS In(05) vmx - [vob.fssvec.OpenFile.file.failed] File system specific implementation of Ioctl[file] failed/var/run/log/hostd.log
YYYY-MM-DD:T:HH:MM:SS Er(163) Hostd[2#####6]: [Originator@6876 sub=Vdisksvc opID=<OPID> sid=52####81 user=vpxuser:DOMAIN\Administrator] ValidateRawDiskDevice: Device vml.##### used for vmfs datastoreYYYY-MM-DD:T:HH:MM:SS In(166) Hostd[2#####6]: [Originator@6876 sub=Vmsvc.vm:/vmfs/volumes/<DATASTORE UUID>/<VM NAME>/VMNAME.vmx opID=<op id> sid=5###1 user=vpxuser:DOMAIN\Administrator] ValidateRawDiskDevice: Rdm device is not supported
VMware vSphere 8.x
The issue occurs when the RDM pointer file or the underlying device is incorrectly flagged as a VMFS datastore.
To resolve this issue, remove and recreate the existing RDM mapping (pointer) files. This process destroys the descriptor file but does not affect data on the actual LUN.
'Device vml.##### used for vmfs datastore' as referenced in Identifying Virtual Machines with Raw Device MappingsIf the issue persist, proceed to engage Broadcom Support to investigate the issue further.
