When attempting to change the BGP Neighbor IP address and max hops in NSX, the Edge uplink goes into 'Inactive' state and does not pass traffic.
In the T0 SR vrf:
VMware NSX
This is the result of a software defect, that causes it to see the next hop as inactive, causing the uplink to be put in the 'Inactive' state.
This issue will be resolved in a future version of NSX.
Workaround:
Setting the "Max Hop Limit" will cause a BGP flap. For this reason, the recommendation is to make these changes during a maintenance window.
If you are contacting Broadcom support about this issue, please provide the following:
Handling Log Bundles for offline review with Broadcom support
