Edge packet drops due to the Edge being busy trying to write large files to frr log as the the log rotation for frr failed in the Edge nodes
Article ID: 383711
VMware NSX
  • Running NSX version 4.2.1
  • The Edge node /var/log/ partition grows in size.
  • If you log in as root and list the the files in /var/log/, you noticed that all /var/log files are growing quite large.
  • The /var/log/frr file path shows only frr.log growing huge almost 28GB and no rotation of frr logs are happening:
  • Due to this disk space usage, Edge node log extraction will be failing on the NSX UI.
  • You may notice intermittent packet drops for traffic traversing the edge node.
VMware NSX 4.2.1
This is a known issue impacting VMware NSX 4.2.1.
When the NSX upgrade happens to 4.2.1, the frr file is removed from the folder /etc/logrotate.d causing the frr log rotation to stop working.
Note: /etc/logrotate.d/frr does not exist and the issue is seen on fresh deployments of NSX 4.2.1.
The issue has been fixed in NSX 4.2.1.3.
Workaround:
Copy and paste the content of frr file (attached to this KB) in the /etc/logrotate.d using vi/vim editor with file name as frr and this should start the frr log rotation automatically every hour
frr.txt get_app
