NSX Edge Loadbalancer Heath Monitor does not send HTTP v1.1 to Backend Servers
Article ID: 338627
VMware NSX Data Center for vSphere VMware vSphere ESXi
NSX-V is at the End of General Support, no feature requests will be implemented (https://knowledge.broadcom.com/external/article/314283/end-of-availability-vmware-nsx-data-cen.html)
Symptoms:
  • NSX-V Edge Load Balancer Health Monitor only uses HTTP v1.0 for it's health checks to backend pool members.
  • If a pool member does not respond to HTTP v1.0 traffic, it will not respond to the LB health check, and pool members will reported as DOWN.
(Note that health check responses back to the load balancer can be HTTP v1.1.)
VMware NSX Data Center for vSphere 6.4.x
It is a limitation on the monitoring heath check for haproxy and built in (Nagios)
There is no resolution.
Workaround:
Allow pool members to respond to HTTP v1.0 traffic.
