- Edge node is configured to use multiple TEP interfaces for overlay traffic.
- Physical networking devices may drop packets as rouge packets on the physical network.
- That is the physical network appliance has seen a packet with an IP address leave a port on the ESXi host using a different MAC address.
- The packet which is leaving an ESXi host vmnic has a mac address assigned to the second interface on the edge node, but has the IP address assigned to the first interface on the edge node or vice versa.
- For example, the edge node may have 2 TEP interfaces, these are seen as eth1 and eth2 on the ESXi host like this:
[root@esx1:~] net-stats -l | grep edge
33554440 5 9 DvsPortset-0 ##:##:##:##:##:d5 edge1.eth0 - This edge interface has IP address 10.1.1.10
50331658 5 9 DvsPortset-1 ##:##:##:##:##:f8 edge1.eth2 - This edge interface has IP address 192.168.1.12/24
50331659 5 9 DvsPortset-1 ##:##:##:##:##:49 edge1.eth1 - This edge interface has IP address 192.168.1.13/24
If we do a packet capture or review physical security logs, we see packets with the following:
source mac as: ##:##:##:##:##:49 - Mac address from edge node eth1
source IP address as: 192.168.1.12 - IP address from edge node eth2
