"available_entries": 0,
"available_entries_in_cache": 0,
"cache_size_per_core": 512,
"description": "Stateful Service FQDN SYNC Pool",
"in_use_count": 524288,
"name": "pffqdnsyncpl",
"size": 524288,
"socket_id": 0},
/var/log/syslog on the Edge node:<Timestamp> <Edge Hostname> b174b10aa4d5 4646 - - <Timestamp> datapathd 5891 stats tname="stats23" [ERROR] {"event_state":100,"event_external_reason":"Edge datapath memory usage is over 85%","event_src_comp_id
":"<UUID>","event_sources":{"pool_name":"pffqdnsyncpl"}} eventId="vmwNSXEdgeMpoolUsage"
<Timestamp> <Edge Hostname> datapath-systemd-helper 5782 - - <Timestamp><Timestamp> datapathd 5891 stats tname="stats23" [ERROR] {"event_state":100,"event_external_reason":"Edge datapath memory usage is over 85%","event_src_comp_id":"<UUID>","event_sources":{"pool_name":"pffqdnsyncpl"}} eventId="vmwNSXEdgeMpoolUsage"
VMware NSX
This issue is resolved in VMware NSX 4.1.1 and 4.2.0, available at Broadcom downloads.
If you are having difficulty finding and downloading software, please review the Download Broadcom products and software KB.
Workaround:
edge> restart service dataplane
