Edge node "UUID" vmId is not found on NSX Manager. Please refer to https://kb.vmware.com/s/article/90072> get upgrade progress-status***************************************************************************Node Upgrade has been started. Please do not make any changes, untilthe upgrade operation is complete. Run "get upgrade progress-status"to show the progress of last upgrade step.***************************************************************************Upgrade steps:download_os [2022-09-16 17:35:52 - 2022-09-16 17:36:21] SUCCESSVMware NSX-T Data Center
VMware NSX
The 'vmMoref id' of the Edge virtual machine is incorrectly populated in Edge upgrade unit metadata.
This issue is resolved in VMware NSX 4.1.0, available at Broadcom downloads.
This precheck error can be ignored if the Edges were deployed on an ESXi host that is not prepared for NSX and the Compute Manager is up and reachable.
If the Compute Manager which was used to create the Edge Transport Node is no longer registered with NSX, the error cannot be resolved by following the workarounds below. The Edges would need to be redeployed on a new Compute Manager in that case.
This issue can be encountered in relation to two different issues (noted below). In the first, a warning is issued for Edge Nodes following the pre-checks. In the second, the edge node upgrade is stuck indefinitely at the 'switch_os' step.
Vmid attribute is missing from EdgeNodeExternalconfigEntityId (VmMoreF) is stale in the DeploymentUnitInstance database table
Workaround for Issue 1: "Vmid attribute is missing from EdgeNodeExternalconfig"
API Method : [This method is available only from NSX version 3.2.3 through 4.1.0]
Note: If the API fix is not applicable due to the version, there is a workaround that involves making changes on the database. Please contact Broadcom Support in such a situation, referencing this KB article and providing the details about this along with the rest of the issue description.
*Ensure there is a viable backup available before taking the steps below.
vmID (VmMoreF Id) from vCenter vmID (VmMoreF Id) from the URL after completing the previous step.
nsxmgr> get nodesGET https://<nsxMgrIp>/api/v1/transport-nodes/<edgeTnId> nsxMgrIp with the FQDN or IP address of an NSX Manager node and <edgeTnId> with the node UUID value obtained in Step 2.--> If it is same then we can proceed to step 5.
--> If its different, please proceed to step 5 but make sure to update the vc_id value with correct ID when executing the step 6 (in the payload)
5. Create the payload for the POST API in the format below, using the output collected from step 3 including the vmID collected from Step 1b. { "vm_deployment_config": { }, "node_user_settings": { }, "node_settings": { }, "vm_id": " " }Example reference output:{ "vm_deployment_config": { "vc_id": "c47f70db-####-####-####-###########", ----> Need to make sure its the correct ID as on the NSX UI compute manager ID "compute_id": "domain-##", "storage_id": "datastore-###", "host_id": "host-##", "management_network_id": "dvportgroup-##", "management_port_subnets": [ { "ip_addresses": [ "192.168.#.# ], "prefix_length": 24 } ], "default_gateway_addresses": [ "192.168.#.#" ], "data_network_ids": [ "dvportgroup-###", "dvportgroup-###" ], "reservation_info": { "memory_reservation": { "reservation_percentage": 100 }, "cpu_reservation": { "reservation_in_shares": "HIGH_PRIORITY", "reservation_in_mhz": 0 } }, "resource_allocation": { "cpu_count": 4, "memory_allocation_in_mb": 8192 }, "placement_type": "VsphereDeploymentConfig" }, "node_user_settings": { "cli_username": "admin" }, "node_settings": { "hostname": "######", "search_domains": [ "example.com" ], "dns_servers": [ "192.168.#.#" ], "enable_ssh": true, "allow_ssh_root_login": true }, "vm_id":"vm-##"}
6. Execute an API call similar to the following: POST https://<nsxMgrIp>/api/v1/transport-nodes/<edgeTnId>?action=addOrUpdatePlacementReferences
In the Body section, use the payload drafted from Step 4 and replace the in the URL above like in step 3.nsxMgrIp
7. Retry the upgrade
Workaround for Issue 2: "EntityId (VmMoreF) is stale in DeploymentUnitInstance table"
If you have identified the issue as Issue #2 noted above, and the NSX version is between 3.2.3 and 4.1.0, the previous POST API workaround described under Workaround for Issue #1 will resolve it.
Note:
If you are contacting Broadcom support about this issue, please provide the following:
Handling Log Bundles for offline review with Broadcom support
