Flash will be end of life at the end of 2020. Network Flow Analysis heavily relies on flash for its menus/pages
https://www.adobe.com/products/flashplayer/end-of-life.html
Release : 10.0
Component : NQRPTA - REPORTERANALYZER
With version 10.0.4 of NFA, the process of removing Flash has begun but is not complete.
NFA will work in conjunction with NetOps portal to provide a solution to the Flash EOL in 2020.
As we progress into 2021, more and more menus in NFA will be recoded in the NetOps Portal
