During vSphere replication, virtual machine disks are experiencing hangs specifically when using VMware Tools version 11.x and later.
Article ID: 318548
VMware vSphere ESXi
This issue is observed during replication. It could be vSphere replication or third-party replication solutions such as Veeam.
Symptoms:
  • After upgrading the VMware tools to 11.x version, the VM disks are going in-accessible during SRM replication.
  • When the replication for the Virtual machine is initiated, the data disk gets hung and will not be accessible until replication is stopped.
  • In the windows event logs, PVSCSI errors can be seen: “Event ID 129 Reset to device, \Device\RaidPort0, was issued.”
  • The issue is not observed when the virtual machine is running on vmtool version 10.2.x/10.3.x.
vmware.log
YYYY-MM-DDTHH:MM:SSZ| vcpu-0| I125: HBACommon: First write on scsi1:0.fileName='/vmfs/volumes/Datastore_name/vm_folder/vm_name_1.vmdk'
YYYY-MM-DDTHH:MM:SSZ| vcpu-0| I125: DDB: "longContentID" = "################################" (was "#############################")
YYYY-MM-DDTHH:MM:SSZ| vcpu-0| I125: DISKLIB-CHAIN : DiskChainUpdateContentID: old=0x42a5825c, new=0x50124967 (###############################)
YYYY-MM-DDTHH:MM:SSZ| vcpu-0| I125: HBACommon: First write on scsi0:0.fileName='/vmfs/volumes/Datastore_name/vm_folder/vm_name2.vmdk'
YYYY-MM-DDTHH:MM:SSZ| vcpu-0| I125: DDB: "longContentID" = "############################" (was "################################")
YYYY-MM-DDTHH:MM:SSZ| vcpu-0| I125: DISKLIB-CHAIN : DiskChainUpdateContentID: old=0x3b36b977, new=0x554f92be (################################)
YYYY-MM-DDTHH:MM:SSZ|vcpu-1| I125: HBACommon: First write on scsi0:2.fileName='/vmfs/volumes/Datastore_name/vm_folder/vm_name_2_2.vmdk'
YYYY-MM-DDTHH:MM:SSZ|vcpu-1| I125: DDB: "longContentID" = "############################" (was "#############################")
YYYY-MM-DDTHH:MM:SSZ|vcpu-1| I125: DISKLIB-CHAIN : DiskChainUpdateContentID: old=0xe76#####, new=0x7fa#### (#############################)
YYYY-MM-DDTHH:MM:SSZ| vmx| I125: GuestRpcSendTimedOut: message to toolbox timed out.
YYYY-MM-DDTHH:MM:SSZ|vmx| I125: GuestRpcSendTimedOut: message to toolbox timed out.
YYYY-MM-DDTHH:MM:SSZ| vmx| I125: GuestRpc: app toolbox's second ping timeout; assuming app is down
vmkernel.log (on the host where the VM is running)
YYYY-MM-DDTHH:MM:SSZ cpu1:5350368)Hbr: 1198: File hbrtmp.1.6660 (groupID=GID-########-####-####-####-############) (offset=0) already exists on server and is identical
YYYY-MM-DDTHH:MM:SSZ  cpu1:5350368)Hbr: 1198: File hbrtmp.2.41 (groupID=GID-########-####-####-####-############) (offset=0) already exists on server and is identical
YYYY-MM-DDTHH:MM:SSZ  cpu7:2099708)Hbr: 2250: Prepared delta (diskID=RDID-########-####-####-####-############) (numExtentsToTransfer=323760)
YYYY-MM-DDTHH:MM:SSZ  cpu7:2099708)Hbr: 2250: Prepared delta (diskID=RDID-########-####-####-####-############) (numExtentsToTransfer=7852153)
YYYY-MM-DDTHH:MM:SSZ  cpu7:2099708)Hbr: 2250: Prepared delta (diskID=RDID-########-####-####-####-############) (numExtentsToTransfer=22991067)
YYYY-MM-DDTHH:MM:SSZ  cpu24:5350431)J6: 2651: 'Prdsan05_56_PRDDB10_Log_SCUReport': Exiting async journal replay manager world
Enable debug log-in for VMware tools:
[YYYY-MM-DDTHH:MM:SSZ] [   debug] [vmsvc] VMTools_ConfigGetBoolean:Returning default value for '[guestinfo] diskinfo-report-uuid'=TRUE (Not founderr=4).
[YYYY-MM-DDTHH:MM:SSZ] [   debug] [guestinfo] GetVolumeUUID:'\\?\Volume{########-####-####-####-############}' is SCSI
[YYYY-MM-DDTHH:MM:SSZ] [   debug] [guestinfo] GetVolumeUUID:SerialNumberOffset(0) isn't valid
[YYYY-MM-DDTHH:MM:SSZ] [    info] [vmsvc] tools service recovered from a hang.
[YYYY-MM-DDTHH:MM:SSZ] [    info] [vmsvc] tools hang detector time sequence 1.00s, 1.02s, 1.01s, 1.02s, 1.00s.
[YYYY-MM-DDTHH:MM:SSZ] [    info] [vmsvc] tools service hung.
VMware vSphere ESXi 6.7
VMware Tools 11.x
The drive hangs while attempting to retrieve the disk UUIDs during the replication process, resulting in a timeout after 60 seconds.
This is fixed in VMware tools version 11.1.5.
Workaround:
  • In tools.conf on the affected guest, enter
[guestinfo]
diskinfo-report-uuid=false
  • vmtoolsd will pick the change up within 5 seconds; A restart is not needed.
