How to Set up CORS in Clarity
Article ID: 236431
Clarity PPM On Premise Clarity PPM SaaS
An error is thrown in app-ca.log files
ERROR 2022-03-02 11:37:02,991 [https-jsse-nio2-8043-exec-31] security.CustomConfigCORSFilter (clarity:none:none:none) Failed to determine cors class java.lang.String cannot be cast to class java.util.List (java.lang.String and java.util.List are in module java.base of loader 'bootstrap')
OR
ERROR 2022-02-17 12:43:36,633 [http-nio-maskedIP-80-exec-36] security.CustomConfigCORSFilter (clarity:none:none:none) Failed to determine cors null
OR you have a CORS warning in Dev Tools when accessing Clarity
Release : Any
A value set for CORS_ALLOW_ORIGIN was incorrect. The values that are not seeded would need to be set up by the Clarity admin.
  1. To add values
    admin system-options -add CORS_ALLOW_ORIGIN http://abc.com -multi
  2. To display the current setup and compare to another environment:
    admin  system-options -list  CORS_ALLOW_ORIGIN
  3. To remove values:
    admin system-options -delete CORS_ALLOW_ORIGIN <domain name>
  4. After this, restart all services
How to ensure the values added are saved correctly in the database:
Run the SQL queries to validate:
SELECT * FROM CMN_OPTION_VALUES where OPTION_ID IN (SELECT ID FROM cmn_options WHERE option_code='CORS_ALLOW_ORIGIN')
or
select v.id, v.value, o.option_code from cmn_option_values v, cmn_options o
where v.option_id = o.id and o.option_code like '%CORS%'
