Stop or start DX NetOps Data Aggregator devices via REST
Article ID: 98856
CA Performance Management Network Observability
How to use REST to change the polling state of select items in DX NetOps Data Aggregator.
Allows for automated and scheduled polling state changes for select devices and/or elements.
All supported DX NetOps Performance Management releases
To start or stop polling for a device via REST
URL: protocol://DAHOST:PORT/rest/tenant/TENANTID/devices/DEVICEID
   protocol      : http or https
   PORT         : PORT DA is running on (defaults: http/8581 https/8582)
   DAHOST    : DA Host Name.
   TENANTID : Tenant ID for the Tenant that hosts the target device.
   DEVICEID  : target Device ID.
Content-Type: application/xml
Body: <Device version="1.0.0"><StopPoll>VALUE</StopPoll></Device>
   VALUE = true (for Stop) or false (for Start).
Example using curl to stop a device
curl -kv -X PUT -u admin -H 'Content-type: application/xml' -d '<Device version="1.0.0"><StopPoll>true</StopPoll></Device>' https://dahost.dom.tld:8582/rest/tenant/8/devices/12345
