Automated deployment engine checks and installs depencies from win32 and win64 marked sections
Article ID: 95537
Updated On: 10-04-2023
When deploying probes via ADE to Windows servers it checks and installs dependencies from sections marked win32 and win64 when the server is 64-bit 2012R2 or 2016.
Any UIM version
This is a normal behaviour, the ADE and distsrv will deploy probes that are under win32 and win64 sections of a custom package.
If the goal is to deploy different probes based on the architecture (x86/x64) then separate custom packages need to be created.
