CA Single Sign On Secure Proxy Server (SiteMinder)CA Single Sign On SOA Security Manager (SiteMinder)CA Single Sign-On
We're configuring CA Access Gateway (SPS) to server https request on port 443, this one doesn't listen to that port and the browser cannot reach the service on port 443.
How can we solve this issue and make the port available ?
CA Access Gateway (SPS) 12.52SP1CR08 on Windows jdk1.8.0_171 32bit;
You needed to run the command configssl.bat -enable on SPS machine to make the https port available for the browser.
