Automation Engine Compatibility Matrix
Article ID: 92794
CA Automic Workload Automation - Automation Engine
List of compatibility information for third party applications, databases, operating systems and discover cross product dependencies.
How to check if a database version is supported?
How to check if a operating system is supported?
How to check which version of Java is supported?
Release:
Component: ARAWSS
We offer a Compatibility Matrx on our documentation page. Please see link below:
https://docs.automic.com/tools/compatibility_matrix
Feedback
thumb_up
Yes
thumb_down
No
