All supported versions of OTK
Scopes should only be separated by a ' ' (space). Anything else is not recommended but the below should help:
- Create a test API
- Use ‘OTK SCOPE Issuing’ only
- Configure it with your test values
- Use a ‘Return template assertion’ to return ‘scope.granted’
- Call the API
Do the same with ‘OTK SCOPE Verification’. Doing this avoids any other policy influencing the result.
