LAC and Gateway integration issue
Article ID: 91904
STARTER PACK-7 CA Rapid App Security CA API Gateway
The LAC has been integrated with the gateway . LAC is running on tomcat. When API is published from LAC UI using the documentation under "Publish using API Creator"
https://docops.ca.com/ca-live-api-creator/4-1/en/configuring/integrate-with-ca-api-gateway/publish-an-api-to-api-gateway#PublishanAPItoAPIGateway-PublishyourAPI
we see an error.
[Error] java.security.cert.CertificateException: No subject alternative names present
LAC 4.1
The cause identified was using an ip address instead of gateway hostname when publishing the API.
use url in format of
https://<gateway_hostname>:8443/lacman/1.0/publish
If the issue is not resolved using this article then other configuration w.r.t mutual gateway authentication needs to be checked.
