Does using SSL cause overhead for XCOM transfers
Article ID: 91872
Updated On: 04-20-2023
XCOM Data Transport XCOM Data Transport - Windows XCOM Data Transport - Linux PC XCOM Data Transport - z/OS
When using SSL encryption for XCOM transfers what can be done about SSL using CPU time in those transfers?
XCOM and SSL are independent of each other. If you use SSL with XCOM, there will be more CPU usage but that is not influenced by XCOM. If there are concerns about the CPU usage with SSL compared to without SSL then that is the responsibility of the SSL Software vendor.
