BODY: [[: not found errors seen in output logs for jobs.
Article ID: 90447
CA Automic Applications Manager (AM)
Release: AAMOS499000-8.0-Automic Applications Manager-OS400 Agent
Component:
Detailed Description and Symptoms
The following errors are seen in the output log file for the jobs:
End of parameter file
job pid 28446
/u01/app/uc4/exec/BODY: [[: not found
starting at Tue May 10 10:05:37 EDT 2011
complete at Tue May 10 10:05:42 EDT 2011
awprint PRINT -j 445331.00 -n b.445331.00 -d /u01/app/uc4/out
Solution
Please contact Automic Support if you are seeing this error message in the log files. They will provide further assistance on the same.
