The agent was working almost a year and suddenly without any Agent or Application change no more metrics were showing.
The problem was that the Wily Agent core file is missing.
The wily.Agent.dll file might have been deleted by an external source, i.e. an AntiVirus program
To resolve this issue, restore the wily.Agent.dll from the last known good backup from the System Restore point.
It is recommend is to check the antivirus’s configuration and exclude the Agent directory to avoid this issue from happening again in the future.
