Problems Installing AS/400 Agent if using OS version is older than V6R1?
Investigation
If you are trying to Install a AS/400 Agent Using a OS version older than V6R1 you might run into some Problems when using an Agent Version that is older than Automic Automation Engine Agent AS400 9.00A.3.129-431
Solution
Please install Automic Automation Engine Agent AS400 9.00A.3.129-431 or higher.?
