UC4 Error on executing BODY script
Article ID: 89190
CA Automic Applications Manager (AM)
Release: AAMOS499000-8.0-Automic Applications Manager-OS400 Agent
Component:
Detailed Description and Symptoms
Errors showing up in job output on target system.
From the log
End of parameter file
job pid 28446
/u01/app/uc4/exec/BODY: [[: not found
starting at Tue May 10 10:05:37 EDT 2011
complete at Tue May 10 10:05:42 EDT 2011
awprint PRINT -j 445331.00 -n b.445331.00 -d /u01/app/uc4/out
Investigation
The problem is with this section of code in $AW_HOME/exec/BODY
if [[ $free_space < 1000 ]]; then
echo Not enough free space $free_space found 1000 required
error_exit "No dsk space" 3
exit 1
fi
The double bracket test works fine in ksh or bash, but when you try to run it in sh(bourne) it will throw the same error since it doesn't know what to with that syntax.
Solution
Change the following line, and remove the second set of brackets.
free_space=100
if [ $free_space -lt 1000 ]; then
exit 1
fi
