UVMS does not start properly in a cluster
Article ID: 88125
CA Automic Dollar Universe
Error Message :
From the uvserver.log file the following error messages were found:
| 2015-11-25 12:26:34 |ERROR| main | org.hibernate.util.JDBCExceptionReporter | Cannot load JDBC driver class 'com.orsyp.driver.FakeSQLServerDriver'
| 2015-11-25 12:26:36 |INFO | main | com.orsyp.central.server.CheckCentralServer | UniverseException: Central IO Connection problem - Connection refused: connect [UJCENT/WPOHACLR17A_MgtServer/X]
Patch level detected:Univiewer Management Server 6.3.00
Product Version: Dollar.Universe 6.3.01
Description :Secondary server cannot start UVMS service after the failover is done.
Cause type:
Configuration
Root Cause: JDBC path doesn't exist in the secondary server as it exist as it is in the primary server.
OS: Windows
OS Version: Windows Server 2012
The entire JDBC driver folder has been copied from primary server to secondary in the same path specified on the unienv.bat file located on UVMS_Mgr\data folder.
JDBC_JAR_PATH_ORSYP is the variable to define the path.
After copying that folder, UVMS was stopped on primary and it stared running on secondary server correctly.
Fix Status: Released
Fix Version(s):
Component: Univiewer.Management.Server
Version: Dollar.Universe 6.3.41
Workaround :
N/A
