Automation Engine Running really slow
Article ID: 87944
CA Automic Workload Automation - Automation Engine
Error Message :
N/A
Automation Engine Running really slow. Unable to do anything with the objects. Unable to run jobs. You can look at the statistic, reports but you can not activate or deactivate anything.
OS Version: N/A
Cause type:
Configuration
Root Cause: Wrong configurations on the automation engine .ini
Adjust the INI file UCSRV.INI to the system environment
  •  Assignment of work processes and port numbers.
  • Assignment of communication processes and port numbers.
  • The port number within an AE system must be explicit, even if the system is distributed over several computers.
  • Connection for the database.
Kill and restart the WPs & CPs
Restart all the processes and agents
Fix Status: No Fix
Fix Version(s):
N/A
Workaround :
N/A
