.bash_profile not executed after running a JOBS or JOBF with non-root Unix user with UID=0
Article ID: 87920
CA Automic Workload Automation - Automation Engine AUTOMIC WORKLOAD AUTOMATION
Error Message :
N/A
The .bash_profile is not run again after running a JOBF with non-root Unix user with UID=0.
Example:
The .bash_profile has the following content:
PATH=/usr/local/bin:/usr/bin:/usr/local/sbin:/usr/sbin:/home/v11/.local/bin:/home/v11/bin:/home/v11/.local/bin:/home/v11/bin
When it is executed inside a Unix Job that has a non-root user with UID=0, it returns the following output:
Cause type:
By design
Root Cause: Automic does not support shadow users. The only user with UID=0 has to be the root user.
OS: Unix
OS Version: N/A
Use the root user as described in the documentation referenced below.
For actual operation, the program ucxj??? can be given the permissions of a privileged user such as root.
  • Change owner to root --> chown root ucxj???
  • Set S-Bit (Set-Userid) --> chmod 4755 ucxj???
Fix Version(s):
N/A
Workaround :
N/A
