Error Message :
N/A
SQL variable in not being resolved.
If a VARA.SQL has a variable, the variable does not get resolved during runtime.
Investigation
Example: SELECT NVL(MAX(FAILURE_EMAIL),'NO_EMAIL') EMAIL FROM (
SELECT FAILURE_EMAIL
FROM PRXL_INF.ETL_SCHEDULE_NOTIFICATION
WHERE UPPER (ETL_FOLDER_NAME) = UPPER ('&FOLDER_NAME#')
AND UPPER (ETL_WORKFLOW_NAME) = UPPER ('&WORKFLOW_NAME#'))
Result: All variables in the example will not be resolved as shown below:
WHERE UPPER (ETL_FOLDER_NAME) = UPPER ('')
AND UPPER (ETL_WORKFLOW_NAME) = UPPER (''))
