Context-sensitive help (F1 Key) does not work for German or French
Article ID: 87586
CA Automic Workload Automation - Automation EngineAUTOMIC WORKLOAD AUTOMATION
Error Message : N/A
This applies to the Java Client:
The context-sensitive help (invoked with the F1 key) always opens in English. This is a legacy aspect.
The feature has been updated so that the current User's language is invoked instead.
If the documentation in the desired language is not found, the system defaults to English.
Cause type: Defect Root Cause: In the Java client, F1 help opens in English. Change this so that when F1 is pressed help is opened in the language that the user is logged in as. If the language is not found then English is the default.
This field was added on 30/03/2017. This article has not been updated yet. Refer to the "Description" or "Workaround" sections for solution information.
Fix Status: Released
Fix Version(s): Components: UserInterface Java
Automation Engine 12.0.0 – Available Automation Engine 11.2.3 – Available Automation Engine 11.1.5 - Available
