RmiServer will not start due to default namespace error with custom SSL Certificate
Article ID: 87549
CA Automic Applications Manager (AM)
Error Message :
AES java.lang.IllegalArgumentException: No default namespace, make sure awenv.ini file contains [default] line.
When a custom SSL certificate is used in Applications Manager v9. The RmiServer will not start, and will throw an error message.
The complete error message found in the RmiServer log will be similar to this:
at com.appworx.agent.AwEnvOptions.A(AwEnvOptions.java:305)
at com.appworx.agent.AwEnvOptions.F(AwEnvOptions.java:200)
at com.appworx.shared.code.server.C.A(ServerUtil2.java:206)
at com.appworx.agent.envvars.EnvVariableResolver.A(EnvVariableResolver.java:122)
at com.appworx.agent.AwEnvOptions.C(AwEnvOptions.java:150)
at com.appworx.server.data.AxRmiServer.main(AxRmiServer.java:821)
ErrorMsg: AwE-9999 Internal error (6/24/15 11:20 AM)
Details: not initialized
java.lang.RuntimeException
at com.appworx.shared.code.server.C.A(ServerUtil2.java:68)
at com.appworx.shared.code.server.C.B(ServerUtil2.java:162)
at com.appworx.agent.envvars.EnvVariableResolver.A(EnvVariableResolver.java:123)
Release: AAMORS99000-9.0-Automic Applications Manager-Oracle - RMS
Component:
Cause type:
Defect
Root Cause: Don't have AwEnvOptions.init() call EnvVariableResolver.init(), call it independently before calling AwEnvOptions.init().
This field was added on 30/03/2017. This article has not been updated yet. Refer to the "Description" or "Workaround" sections for solution information.
Fix Status: Released
Fix Version(s):
Applications Manager 9.1.2 - Available
Workaround :
Do not use custom SSL certificate.
