AE System Configuration for running more than 100,000 Agents
Article ID: 87527
CA Automic Workload Automation - Automation Engine
Error Message : N/A
Following are recommendations for AE systems running more than 100,000 agents:
1) tcp_nodelay has to be enabled (this parameter is part of the ucsrv.ini)
tcp_nodelay=
This defines the use of the Naqgle algorithm for the connections of the Automation Engine.
Allowed values: "0" (recommended default value) and "1"
"0" - This activates the Nagle algorithm. "1" - This procedure is not used.
Set this parameter only in close cooperation with Automic Support.
2) tcp_keep_alive has to be set to 30 (this parameter is part of the ucsrv.ini)
tcp_keepalive_time=
The time interval in seconds in which keep-alive packets are sent in order to keep connections.
The default value that depends on the system environment is used when you do not define this setting or when you define the value 0.
3) alivetimeout has to be set to 900 (this parameter is part of the ucsrv.ini)
alivetimeout=
The duration in seconds in which the AE.Nonstop-Server expects a message from the primary work process. If this time span is exceeded, the AE.Nonstop-Server becomes the primary work process.
Default value: 600 seconds
Be careful when you change this parameter. The selected time span should be high enough because the primary work process is busy for quite some time if comprehensive database transactions take place and cannot send keep-alive messages
If you are using Oracle as your database, modify the Oracle client (sqlnet.ora) as follows:
TCP.NODELAY=yes SQLNET.EXPIRE_TIME has to be set between 1 and 5 - 1 should be the prefered value
Change the following settings in your system wide variable UC_SYSTEM_SETTINGS in client 0, folder DIV_VARIABLES.
This setting defines whether the IP address of agents should be used for checking the license.
Allowed values: "Y" (default) and "N" "Y" - The IP address is used for checking the agent's license. The license is not counted if an agent of the same IP address is already logged on. "N" - The IP address in not checked when the agent logs on. This saves time when numerous agents log on. Note that every agents requires its own license in this case.
Various server settings for performance improvement and trace outputs.
Format: 15-digit string
By default, all options are deactivated.
11th digit
Extended output of time-critical database accesses in the log file.
The Automation Engine logs the bind parameters of all time-critical database accesses whose select statements take more seconds than specified in this server option. Any number between 1 and 9 can be specified.
Note that regardless of this setting, bind parameters will not be logged in insert statements.
When this option is used, 3 is often recommended. This way the bind parameter of all selects that take more than 3 seconds will be logged. Therefore, the Automation Engine logs the BIND VARIABLES for long running SQL statements within the LOG file without the need for a trace.
ILM must be used for DB maintenance. See reference section below.
Change the following settings in the agent variable UC_HOSTCHAR_DEFAULT in client 0, folder HOST_VARIABLES
Y - The agent sends its log-file messages also to the Automation Engine which stores it in the Agent object's report. N - The agent does not send log messages to the Automation Engine. Doing so improves the AE system's performance.
Modify the agent variable UC_EX_HOSTCHAR in client 0, folder EX_VARIABLES.
Remove all the agent entries in this variable and create an entry with key * and value DEFAULT.
To get all of them in place the AE + CP must be restarted (could be done in a round robin).
This field was added on 30/03/2017. This article has not been updated yet. Refer to the "Description" or "Workaround" sections for solution information.
