Description :Impossible to start Dollar universe after a system crash / power failure. Impossible to launch dollar universe command line.
Cause type: Other Root Cause: The error "too many open files" probably led to the corruption of the files u_proxy.dta and u_fmsc60.dta u_proxy.dta: file that contains the system user patterns, pushed from the uvms, and therefore the reason of the message "Access Denied" on every command launched from the system.
OS: All
In order to fix the issue, a restore of the files u_proxy.dta / u_fmsc60.dta / u_fmsc60.idx from a previous backup is needed. The procedure would be: 1. Stop the node 2. Backup the current files 3. Restore the files on the folder data: u_proxy.dta / u_fmsc60.dta / u_fmsc60.idx 4. Launch an offline reorganization 5. Start the node again and launch a full synchronization from the univiewer console.
