Communication problems between token server and gateway.
Article ID: 87051
CA Automic Sysload
Affects Release version(s): 5
Error Message : When a port scan software tried to scan the token server this errors could appear in the token server log: ####################### sldtkd - [thread:'ORecvHandler 4']: Error(10054) while receiving request (-5 bytes received) #######################
When several license requests were done by the agents at the same this error could appear on the log of the gateway or on the master token server: ####################### Fri Feb 8 13:23:26 2013: LPtrVerif - OSockComm.c[242] - Socket close error errno=9 #######################
