Connection problem to upgraded UVMS from a cluster configuration
Article ID: 86953
CA Automic Dollar Universe
Error Message :
The connection to UVMS fails with an error message :
The UVMS has several definitions
Patch level detected:Univiewer Management Server 6.3.01
Product Version: Dollar.Universe 6.3.01
Description :After upgrading an UVMS node previously installed in an active / passive cluster based on 6.2.xx version, the connection to this active node upgraded fails
OS: All
Cause type:
Configuration
Root Cause: When Upgrading an UVMS cluster with external database, the user used to perform the upgrade must have the write access on the external database to perform the unidlt command in order to repair the data inconsistency
Use an authorized user to perform the upgrade, also check in the table UNI_UV_NODES if all the unnecessary UVMS nodes have the value 1 in the IS_DELETED column
Fix Status: No Fix
Workaround :
N/A
