Supervision script does not work (no output the output log) when compatibility is set to V5.3
Article ID: 86895
CA Automic Dollar Universe
Error Message :
N/A
Patch level detected:Dollar Universe 6.0.00
Product Version: Dollar.Universe 6.0.0
Description :Generic Supervision script does not work(no output the output log) when compatibility is set to V5.3.
Cause type:
Defect
Root Cause: N/A
Update to the fix version listed below or a newer version if available.
Fix Status: Released
Fix Version(s):
Component: Application.Server
Version: Dollar.Universe 6.2.21
Workaround :
N/A
Feedback
thumb_up
Yes
thumb_down
No
