Unijob rename function does not work for more than 10 characters
Article ID: 86690
CA Automic Dollar Universe
Error Message :
In a popup error:
An invalid Job name has been used : Invalid Job - <JOBNAME>
Patch level detected:Univiewer Console 6.1.00
Product Version: Dollar.Universe 6.1.0
Description :Unijob rename function does not work for more than 10 characters
Cause type:
Defect
Root Cause: N/A
OS: All
OS Version: ALL
Fixed in Unijob 1.4.5
Fix Status: Released
Fix Version(s):
Component: Univiewer.Console
Version: Dollar.Universe 6.1.41
Workaround :
Use the duplicate function instead.
