Time control management does not monitor long duration jobs on Windows
Article ID: 86446
CA Automic Dollar Universe
Error Message :
The following error in the history trace:
control duration: error during custom script submission
Patch level detected:Dollar Universe 6.0.00
Product Version: Dollar.Universe 6.0.0
Description :Time control management does not work to monitor long duration jobs on Windows
When trying to use Time Control Management to monitor long duration jobs on Windows, and chose to execute a script, the following error can show in the history trace:
Reproduction Procedure : In the uproc script, use a uxsleep of 20s.
set the max duration to 10s.
and chosen the Execute Script option.
C:\temp\test.bat
The test.bat contains:
@echo off
echo test > C:\temp\test.log
set resexe=0
Run the uproc and after 10s, there is an error in the history trace.
OS: Windows
OS Version: All
Cause type:
Defect
Root Cause: N/A
This is fixed since Dollar Universe 6.1.01
Fix Status: Released
Fix Version(s):
Component: Application.Server
Version: Dollar.Universe 6.1.01
Workaround :
N/A
