Description :If Reporter client is installed under c:\Program Files (x86)\Reporter\client\ or another path with a space, the extraction and report uprocs are not working properly.
Cause type: Defect Root Cause: N/A
OS: All
Update to the fix version listed below or a newer version if available.
