Problem when extracting package with Uprocs OAPP_SET or OAPP_PGM
Article ID: 86249
Automic Dollar Universe
An error message when creating DU package with Oracle UPROCs type "OAPP_SET".
Unable to extract package when attempting to extract a package containing all the Uporc definitions on one node; seeing the error below:
The UVC Pop-up error message:
On environment [UJCENT/<uvms_server_MgtServer>/X]:
Package <Package Name> on <uvms_server_MgtServer>: java.lang.NullPointerException.
In the UVC log file :
|2013-12-07 11:33:42,645|ERROR||BackgroundWorker-29|com.orsyp.kmeleon.environment.ExceptionManager|An error occured on ENVIRONMENT: (node = uvms_server_MgtServer environment = [UJCENT/uvms_server_MgtServer/X])
com.orsyp.UniverseException: Problem when extracting package
at com.orsyp.std.deploymentpackage.PackageStdImpl.extract(PackageStdImpl.java:138)
at com.orsyp.api.deploymentpackage.Package.extract(Package.java:337)
at com.orsyp.kmeleon.universe.DUBussines.extractPackage(DUBussines.java:4895)
at com.orsyp.kmeleon.document.owlspackages.comon.controller.AbstractPackagesController.prepareModel(AbstractPackagesController.java:150)
at com.orsyp.kmeleon.controller.KmeleonCustomController.prepareDocumentModel(KmeleonCustomController.java:97)
at com.orsyp.kmeleon.guibuilder.controller.ControllerInvocationHandler.executeTemplate(ControllerInvocationHandler.java:349)
at com.orsyp.kmeleon.guibuilder.controller.ControllerInvocationHandler.access$400(ControllerInvocationHandler.java:44)
at com.orsyp.kmeleon.guibuilder.controller.ControllerInvocationHandler$3.run(ControllerInvocationHandler.java:284)
at com.orsyp.kmeleon.guibuilder.controller.ControllerInvocationHandler.redirect(ControllerInvocationHandler.java:316)
at com.orsyp.kmeleon.document.documenttype.AbstractAssembledDocumentContent.createDocumentContent(AbstractAssembledDocumentContent.java:77)
at com.orsyp.kmeleon.document.DocumentFactory$2.run(DocumentFactory.java:543)
at java.util.concurrent.Executors$RunnableAdapter.call(Unknown Source)
at java.util.concurrent.FutureTask.run(Unknown Source)
at java.util.concurrent.ThreadPoolExecutor.runWorker(Unknown Source)
at java.util.concurrent.ThreadPoolExecutor$Worker.run(Unknown Source)
at java.lang.Thread.run(Unknown Source)
Caused by: java.lang.NullPointerException
at com.orsyp.api.uproc.oapp.RequestSet.setName(RequestSet.java:106)
at com.orsyp.owls.impl.uproc.UprocMsgHelper.populateObject(UprocMsgHelper.java:3118)
at com.orsyp.owls.impl.deploymentpackage.PackageMsgHelper.transformToPackageElement(PackageMsgHelper.java:985)
at com.orsyp.owls.impl.deploymentpackage.PackageMsgHelper.fillPackageFromMessage(PackageMsgHelper.java:958)
at com.orsyp.std.deploymentpackage.PackageStdImpl.extract(PackageStdImpl.java:125)
Defect
Update to the fix version listed below or a newer version if available.
Fix Status: Released
Fix Version(s):
Component: Univiewer.Console
Version: Dollar.Universe 6.1.41
