Uproc script does not display when using the uxshw command
Article ID: 86043
CA Automic Dollar Universe
Error Message :
There are no errors, the scripts just stop being displayed.
Patch level detected:Dollar Universe 6.4.01
Product Version: Dollar.Universe 6.4.01
Description :When running the "uxshw upr" command, the scripts for CL_INT type uprocs will display until the command encounters a CL_EXT type uproc.
Afterwards, the script does not display for all future CL_INT type uprocs.
Cause type:
Defect
Root Cause: A flag was not being reset after a uproc of type CL_EXT was displayed in the output of the uxshw command.
OS: All
An upgrade to DUAS version 6.6.01 is required
Fix Status: Released
Fix Version(s):
Component: Application.Server
Version: Dollar.Universe 6.6.01
Workaround :
N/A
