It is not possible to apply an offset to the proccessing date unless the offset is not zero.
Article ID: 85842
CA Automic Dollar Universe
Error Message :
No error message.
Patch level detected:Dollar Universe 6.2.00
Product Version: Dollar.Universe 6.2.0
Description :Not able to include the offset in the processing date, unless the offset is set to 0.
uxupd tsk tsk=TESTTASK mu=* techinf pdate_offset=Y
This does not enable the offset calculation on the processing date.
Cause type:
Defect
Root Cause: N/A
Update to the fix version listed below or a newer version if available.
Fix Status: Released
Fix Version(s):
Component: Application.Server
Version: Dollar.Universe 6.2.41
Workaround :
N/A
Feedback
