In Uproc Enhanced Status Management section, if a stringĀ is entered with a leading space, it is ok. The string with leading space can be detected by Dollar Universe. . When the U`proc is edited again via UVC, the leading space in Enhanced Status Management will be removed.
Cause type: Defect Root Cause: N/A
OS: All
Update to a fix version listed below or a newer version if available.
Fix Status: Released
Fix Version(s): Component(s): Univiewer Console Dollar Universe 6.2.41 - Available
Workaround : Manually put back the missing space each time the Uproc is edited
