Cannot start an engine using "uxstr atm" command
Article ID: 85536
CA Automic Dollar Universe
Error Message :
/bin/uxstr: error while loading shared libraries: libidn.so.11: cannot open shared object file: No such file or directory
Patch level detected:Dollar Universe 6.0.07
Product Version: Dollar.Universe 6.0.0
Description :Can't start an engine in command line with "uxstr atm "
Cause type:
Configuration
Root Cause: This happens on a 64 bits Linux if the FTP library is not installed.
OS: Linux
OS Version: Redhat 5
The solution is to install the FTP library.
Also, the recommended command is now "uxstr FNC"
Fix Status: No Fix
Workaround :
N/A
