Problems setting tim.urlPathGetPrefix in tess-default/tess-customer.properties.
The default value for that property is /wily/cem/tim/mod_python/timfiles.
This is used for listBTstats, listDefects and listEvents operations.
The result is this error in the MOM/Tess log:
Manager.com.timestock.tess.services.tim.TimIo] http://10.10.10.110:80/ca/apm/tim/mod_python/timfiles/listEvents: HTTP response: 404 Not Found
An apparent bug -- tim.urlGetPathPrefix in com.wily.apm.tess_10.5.2.jar is incorrect. It doesn't match tess-default.properties, which has a parameter called, "tim.urlPathGetPrefix."
The workaround is using urlGetPathPrefix instead of urlPathGetPrefix in tess-default.properties/tess-customer.properties to match the coded property.
This is targeted to be fixed in APM 10.7. Support can track the status of DE307141 or US403714.
