"Save and Close" feature does not work for Uprocs from a node 5.6
Article ID: 85235
CA Automic Dollar Universe
Error Message :
N/A
Patch level detected:Dollar Universe 6.5.00
Product Version: Dollar.Universe 6.5.01
Description :Save & Close objects (tested on Uprocs) for 5.6 nodes does not close the screen. It looks like nothing has been done or saved.
Changes done are indeed saved.
Cause type:
Defect
Root Cause: N/A
Upgrade to version 6.6.01
Fix Status: Released
Fix Version(s):
Component: Application.Server
6.6.01
Workaround :
N/A
Feedback
thumb_up
Yes
thumb_down
No
