JDE Jobs abort using scripted solution for Applications Manager
Article ID: 84944
CA Automic Applications Manager (AM)
Error Message :
Cannot find jcjobnumber in response file - possible error
JDE jobs will abort with the following error message in the job's output file:
-rw-rw-r-- 1 jdeb9 jdeb9 198 Sep 15 06:46 /pd/appworx8/am/run/145034762.00_out.xml
jcjobnbr
* Finished on Fri Sep 15 06:46:14 EDT 2017 with status ABORTD (ABORTD)
Cause type:
Configuration
Root Cause: This is an issue on the JDE side.
OS Version: N/A
The error message should reference a <JobID>_out.xml file.
Example:-rw-rw-r-- 1 jdeb9 jdeb9 198 Sep 15 06:46 /pd/appworx8/am/run/145034762.00_out.xml
Inside that file should be the error message that details why the job is aborting.
Example:<?xml version='1.0' encoding='UTF-8' ?><jdeResponse pwd='' type='ube' user='' environment=''><ACTION TYPE='ERROR_MESSAGE'><ERROR VALUE='JDB_InsertTable failed for F986110.'/></ACTION></jdeResponse>
In the above example, the issue is with the JDE table F986110.
Contact your JDE Administrator to investigate why the application cannot insert into that table.Fix Status: No Fix
Fix Version(s):
N/A
Workaround :
Resetting the jobs initially may allow them to run.
BEWARE: Eventually, the reset jobs will fail as well.
Feedback
thumb_up
Yes
thumb_down
No
