Using a variable for path for external script in CL_EXT Uprocs leads to unwanted errors in job logs and the job aborts.
Article ID: 84725
CA Automic Dollar Universe
Error Message :
In the job log:
Uproc script %VARIABLE%\script.bat not accessible.
Patch level detected:Dollar Universe 6.0.00
Product Version: Dollar.Universe 6.0.0
Using a variable to give the path of an external script in CL_EXT Uprocs led to unwanted error messages in the job logs and the job is aborted.
Cause type:
Defect
Root Cause: N/A
Release: ADUNAS99000-6.0-Automic Dollar Universe-AS
Component:
Update to the fix version listed below or a newer version if available.
Fix Status: Released
Fix Version(s):
Component: Application Server
Dollar Universe 6.1.21 - Available
Workaround :
N/A
Feedback
thumb_up
Yes
thumb_down
No
