Error Message :
U00003210 Logon error :Acces denied
There is an issue where LDAP suddenly stops working for all LDAP users with the following error:
LDAP.Sync is not used. LDAP users are identified by there Distinguished Name that has to be entered manually in the LDAP settings of the user object:
Authentication for local users still works as expected.
